The PTC Community email address has changed to community-mailer@ptc.com. Learn more.
Add the ability to add the query selections to show in the heading
A way to show the report selection  criteria such as the As Of Date ##/##/##  in the heading of the report
This function would allow you to pick which of the selection in your query select you want to appear in your heading as a field added to the heading.
That way you can show your query selection criteria on the report heading, like when you run a report as of a date it would be beneficial to see what information the report was run for. Instead of having to hand type the information in to the report each time you change the query selection criteria.
And the same ability to show this on your charts on Dash boards as well.
2 Comments
GauravPhadtare
KartikOak
Status changed to: Archived
In line with the linked Idea this is being Archived.
This action is based on the age of your idea and the total number of votes received.
