Currently, in the Show items containing field in the Create Change Package dialog box, there is no functionality of filter by Integrity Project
Also, as mentioned in the PTC case
https://www.ptc.com/en/support/article?n=CS83725
I would like to propose this as a request for enhancement functionality since if the list gets long, it would be hard to find a specific item. See attached
