Over the time there will exist a lot of access groups within Integrity, created for lots of different Subproject nodes.
It would be a great benefit, if there would exist an Admin Report which would bring out the info, WHERE access groups are in use.
The report should also contain infos from Archive as well as for Shared Subprojects.
