When you have to admin and support some hundred installed clients, what would realla help is a way to publish a "complete" default configuration for the client's gui.
Currently there are ways to configure a viewset and all it's option:
- menu content (which command is visible (on Toolbar ) or not )
- view behavior (floating or "inline" position)
- content of context menu's in views
but all these setting do only apply for the viewset's "inline" views.
There should be a admin tool to define the default settings for a floating view, especially things like:
- a default filters e.g. for a history view
- the content of the context menu e.g. in a sandbox view
- the commands available in the menu e.g. in an item detail view
- Custom Buttons. e.g. in the Test Result Editor
