Agile Solution Template in ALM
ptc-5063479
I was requested to implement agile solution template on pre-existing ALM solution on the single Integrity server. Could you share your opinion on this? What will be pros and cons if we implement agile solution over the existing Integrity solution?
Regards
Sarath
KaelLizak
(To:ptc-5063479)
Hello Venkata,
There is actually an Agile solution as well. My understanding is that it was designed to co-exist with the ALM solution. Please contact PTC Integrity Support if you are interested in obtaining this template.
Kael
Kind Regards,
Kael Lizak
That is correct; the ALM and Agile solutions may be installed side-by-side, however, they do not interact without some configuration to make them do so. We recommend that your engage PTC Global Services to do an assessment and configure the solutions in a way that meets your business process needs.
