Java-based PTC products like Windchill RV&S are now supporting alternatives to Oracle like Amazon Corretto. Most of the Modeler functionality does not need Java, however the XMI Import/Export requires currently Oracle Java RTE, 32bit. A lot of customers do not want to use Oracle Java anymore, so it would be good to use the same alternatives like for RV&S or Windchill.
