I frequently use the filtering in the client - using "where" - to query content items in documents, changes requests, defects, etc. It would be very convenient if after defining the query in the client, I was able to have the ability to create a query using the specifications from the where filter. This would be especially helpful if you are new to Integrity. It would allow you to create a base query and then modify it as necessary. For instance, when I began creating queries, I didn't understand the "Is content node" concept. If I was able to create a query from the client filtering, it would have made query creation more intuitive.
