Bulk edit for text fields (shorttext and longtext) offers full replacement only. For logging fields, this is really irrelevant because of how logging works, but for other text fields, I propose adding the capability of using field substitution as an option.
Example 1: Allow the use of syntax such as: Prefix 1: {Summary} to allow adding a prefix to the existing Summary fields on the selected items, instead of completely replacing the contents.
I will be creating another enhancement request to improve upon the existing substituteFields() capability on the issueDeltaBean. That, combined with this request, would make for much more capable editing options.
