Allow parts to be changed into full ports and full ports to be changed into parts
0 Kudos
It would be very useful to be able to change a part into a full port and vice versa. This could be by the simple expedient of dragging a part on to the containing block's boundary on an IBD. Conversely, dragging a full port off the boundary and into the composition area of the owning block on an IBD.
In the browse trees, a similar result might be obtained by being able to toggle the <<fullPort>> stereotype, of the use of a context menu refactoring command.
The need for this is justified by the evolution of a model that changes whether or not a block's internal parts should be exposed as its interfaces, or not.
2 Comments
PatrickOllerton
Status changed to: Under Consideration
Thanks, I've captured this in ART21-21068042
regards,
Patrick
olivierlp
Community Manager
Status changed to: Archived
