I would like to be able to create simple computed fields in a query definition where the computed field value is based on fields in the returned items. For example, in a query that lists items with an Actual and Estimate field, I would like to be able to compute an Accuracy field, per item returned, based on those values from the query definition itself.
From a UI or API perspective, these computed fields would need to somehow be differentiated from real fields to reduce the number of occurrences of users trying to find that field for reporting.
