Allow the 'Text Editor' profile dialog to be used when creating a new object from a profile menu
0 Kudos
The 'Text Editor' profile dialog can only be used to edit data for an existing object.
It would be helpful if it could be used when creating a new object from a profile menu option (i.e. within RunMenuUI), to allow a descriptions etc. to be entered before the object itself has been created, with a default value. This would be analogous to an InputBox (but allowing multi-line entry).
As a work around I have placed a Text Diagram in the profile itself, solely to use the Description field as the target for Text Editor.
However, this doesn't allow entry of a custom default value since the profile itself has to be Protected and changing the Description to set this default prior to invoking the Text Editor requires Write access.
2 Comments
PatrickOllerton
Status changed to: Under Consideration
hello,
Thanks for the suggestion, I've added to our backlog (ID: ART21-22869747) and we will consider for the future.
regards,
Patrick
olivierlp
Community Manager
Status changed to: Archived
