The PTC Community email address has changed to community-mailer@ptc.com. Learn more.
Attempt to launch MKS Integrity Client Timed out
ptc-5871581
1-Newbie
This is my first time with MKS. We are using MKS Integrity Client, on windows XP. Installation of mksClient.bin runs fine, but anything I try, I get the following error.
Attempt to launch MKS Integrity Client Timed out. To solve this please try the following:
- Verify that the user you are logged in as has read and write permissions to the Integrity Client install directory.
- Make sure the Integrity Client install directory is the very first entry in the path.
I'm able to read/write in integrity client install directory, so that cannot be the issue. Please provide your comments
1 ACCEPTED SOLUTION
Hi Bhargavi,
Have you checked the Path environment variable on your machine? The first entry in your Path needs to point to the Integrity Client's bin directory.This is a windows setting. You can find it by clicking the Windows Start Menu > Right-Click My Computer > Properties > Advanced > Environment Variables.
Within the list of System variables, look for the Path variable - make sure the Integrity Client's bin directory is the first enrty in the Path and if it's not, edit it.
Save those changes and relaunch your client.
1 REPLY 1
Hi Bhargavi,
