Today, when connecting two Ports with a Biding Connector, the 'Conjugated' option is not synchronized. As the Binding Connector means a delegation, this should happen. We even have the "<<equal>>" stereotype applied to this connector.
Without this feature, we can end up having an 'Input' Proxy Port delegated to an 'Output' Proxy Port, which makes the model inconsistent.
