You can do bulk changes on several items on field values but not on their formatting, which could be quite useful especially in the case of headings. There are currently too many clicks involved to make a heading a good heading: you have to change the category to heading and then you need to change the format to heading. The former you can do in bulk, but the latter is really a pain to change the formatting of all headings in a document.
