Can I add a sum to a stacked bar chart at the top of each bar?
cbrendler
Hello all,
I created some charts for my dashboard. Each chart is a "vertical stacked bar graph". Can I add a sum to each stacked bar in the chart at the top of each stacked bar?
Thank you for your help,
Christian
KaelLizak
(To:cbrendler)
Hello Christian Brendler‌,
I'm not sure exactly what you're asking. Could you give us a more detailed explanation of what you are trying to do?
Kael
Kind Regards,
Kael Lizak
Hello Kael,
thank you for your answer.
Let me show you a screenshot.
I have created this Chart. The numbers of each result is printed in the bar.
I would like to print the sum of all bars on top like I drawed the 32 and the 2.
Christian
KaelLizak
(To:cbrendler)
Hello Christian,
Thanks for clarifying!  I completely misunderstood where you were going for with that.  Unfortunately, what you're asking for is not possible within Integrity.  You could create a Product Idea to propose this as a new feature.
Alternatively, you could export the data to Excel, and use Excel charting (assuming it can do this)
Kael
Kind Regards,
Kael Lizak
