Can I open the 'View Documents' on second monitor?
ysohn
When I create a trace between two documents, I opened two documents in same monitor.
I use dual monitor now.
If one document windows was opened in main monitor and another document window was opened in second monitor, it is more comfortable for me.
1 ACCEPTED SOLUTION
Hello Yousun Sohn,
what we need is a custom menu entry, with the following code behind.
im viewsegment --user=%MKSSI_USER% --gui %MKSSI_DOCUMENT%
It can be inside a simple batch file, or a powershell script, or a small java program (that's what I did).
Hope this helps, any followup question is welcome.
Volker
6 REPLIES 6
KaelLizak
(To:ysohn)
Hello Yousun Sohn‌,
This is not currently nicely handled by the Integrity client.  Please open a ticket with PTC Integrity Support to add your organization to CS91123.
Kael
Kind Regards,
Kael Lizak
Hello Yousun Sohn,
Volker
KaelLizak
(To:VolkerEckardt)
Hello Yousun Sohn‌,
Did Volker Eckardt‌'s answer resolve this issue for you?
Kael
Kind Regards,
Kael Lizak
Yes, his answer is clear.
KaelLizak
(To:ysohn)
Thanks Yousun Sohn‌ for letting us know what resolved the issue for you!
Kind Regards,
Kael Lizak
ysohn
(To:ysohn)
Thanks for your helping!!
Your solution is good for me
