Hello!
We are using Integrity 10.8 with MKS Domain Security Managment for Users and Permissions. Now we like to migrate to a LDAP or ADS solution.
We have some questions regarding the technical solution design and migration, maybe someone has done this procedure allready and may share some informations.
I already check the documentation and its unclear how do migrate from actual mks domain management to a ldap management with maintain the same user/group settings?
Thank you very much
I'm assuming the userids are not changing. If you need to change the userids, then it is much more complicated (it involves DB changes or losing history of users) and I'd recommend opening a case with Technical support .
