Changing the hostname
DanR.
I'm creating a plan to upgrade our MKS Integrity 2009 SP7 (AIX) test server to PTC Integrity 10.6 (AIX). In the is.properties file there is a setting mksis.hostname=mks-test.
Server URL is http://mks-test:7001. The actual name of the server is something different. I changed the hostname setting in the is.properties file to ptc-test. I stopped ans started the server using mksis stop and mksis start and I saw errors in the server.log:
2015-04-14 07:33:20,103 DEBUG [mksis.IntegrityServer] DEBUG(0): mks.frame.client.ConnectionException -- mks.frame.client.ConnectionException: MKS124871: Could not establish server connection (it may be down). Details: Error resolving hostnames; nested exception is: java.net.UnknownHostException: ptc-test
What did I miss?
1 ACCEPTED SOLUTION
wspadola
7-Bedrock
(To:DanR.)
Daniel,
This error suggests that there is no DNS entry for "ptc-test" to be mapped to any IP address at all. You will need to discuss having this entry created with your network administrator. The only alternative is to use a local HOSTS file, but this is very cumbersome.
Changing the value of mksis.hostname will also require using a diagnostic (at the very least) to re-map existing change packages within the database to a different mksis.hostname value. Please see https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS172703 There are also certain steps in the following article https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS115211&lang=en_US that I would suggest reading over as well, namely step 8 and 9.
I would suggest opening a case with support so we can help with any additional scope of changes for this server.
5 REPLIES 5
pmerkle
(To:DanR.)
Did the server start although there is this error in the log file?
Is the new server name reachable from the client (e.g. "ping potc-test") ?
DanR.
(To:pmerkle)
No. The server.log repeats the error every 5 seconds. The client reports this error -> "Error connecting to ptc-test:7001 (it may be down): The IP address of the host could not be determined"
wspadola
7-Bedrock
(To:DanR.)
Daniel,
DanR.
(To:wspadola)
We are not moving the server to new hardware. And we are not using change packages at this time.
DanR.
(To:wspadola)
I opened a case.
