Citrix support for Integrity
We run Integrity LM on a central server/db. For people that are travelling or are in remote sites we typically recommend to use Citrix for these type of applications (client to central server). For Integrity, this is currently not supported.
This is the same RFC as CS84832
4 Comments
kokici
8-Gravel
Hi acoosemans
I assume you are able to run Integrity ILM Client on Citrix on your won risk, even this is still not supported. We do this as well but from time to time some users are getting the error "Failed to start database <path to the user folder...\clientdb\>...and cannot start the Integrity Client at all. Only after the Citrix profile has been deleted completely for the user, this are able to use the Integrity Client again. Have you seen this in your environment ?
Thanks in advance.
acoosemans
Hi @kokici,
Thanks for sharing your experiences.
We didn't deploy it in Citrix, actually we didn't really get to testing it. So I can't tell.
Adriaan
KartikOak
Status changed to: Alternate Solution
In the long term, the Refreshed Web UI project would resolve this scenario.
Kartik
acoosemans
Agreed
