Class Diagram - Dependencies Updated in the Model Correctly
0 Kudos
On a SysML Requirements Diagram you can create a Requirement (e.g. Req1) and add two items (e.g. Class1 and Class1) with a satisfy link from Class1 to Req1. If you then move the link (source) from Class1 to Class2 and look in the Relationships Browser for Req1 then the satisfy link has moved from Class 1 to Class 2 as expected. However, if you repeat this on a Class Diagram the diagram shows the new link being moved but the Relationships Browser still shows the satisfy link to Class1. The behaviour on the Class Diagram should be the same as the Requirements Diagram.
2 Comments
PatrickOllerton
hi Kevin,
Yes this is an issue and we intend to fix asap.
Support have logged this as Case Number: 13516230 and will be in contact to provide further guidance.
regards,
Patrick
PatrickOllerton
Status changed to: Delivered
hi Kevin,
Integrity Modeler 8.4 provides a tool to repair inconsistent links. Refer to Help topic "Repairing inconsistent links".
regards,
Patrick
