Conflict automatic merge
gfontana
8-Gravel
Hello everyone,
 suppose to have this scenario:
  •   A developer checks out (non exclusive lock) a file locally, and modifies it.
  •   Another developer checks out the same file (non exclusive lock), modifies it and makes a check in.
  •   The first developer tries to check in the file from local to remote after the other developer.
Now the question is:
 If there are no conflict Integrity perform an automatic merge (as GIT do) highlighting the difference by compare the content?
 I take for granted that conflicts must be resolve manually.
Thank you !
1 ACCEPTED SOLUTION
awalsh
(To:gfontana)
The default settings are that the first developer will be prompted to resynchronize to member revision, merging as needed:
If they choose to resynchronize and merge, they will be prompted to choose the type of merge:
If they choose Automatic and there are conflicts, they will then be prompted to launch the conflict resolution tool.
You can change the defaults in the user preferences. Select File > Preferences. Expand Configuration Management then Commands. The Check In and Merge commands are the ones to change. If you want everything as automatic as possible, then choose On Newer Revision: Resychronize for the Check In preference, and Merge Type: Automatic.
awalsh
(To:gfontana)
awalsh
(To:awalsh)
One more thing: After the merge is done, whether automatic or manual, the Check In is marked as Deferred. The user must select Member > Submit Deferred or submit the change package to complete the Check In.
