Consistent Handling of Port Metatypes
Current Situation: When creating a port with a type it is created as "role", when it is created without a type, it is created as "attribute" (visible in Tellme). BUT: When a type is assigned to the initially non-typed port lateron, the metatype "attribute" does NOT change to "role".
Problem: This causes additional (API/wrapper programming) effort for handling Ports, particularly regarding Model information export, because they have to be handeled differently.
Idea: We suggest ports to be handeled in Modeler in a way such that untyped Ports (=Attributes) are changed to roles when they get a type assigned so that finally the same things are always of the same metatype.
2 Comments
PatrickOllerton
hi Daniel,
Thanks for the idea and apologies for the slow reply.
This capability is planned in ART10-19300937. We have no firm plans to implement at the moment, but will consider for inclusion in Integrity Modeler 9.1 and provide any updates here.
regards,
Patrick
PatrickOllerton
Status changed to: Under Consideration
