Pre Condition
User anywhere around the globe is checking a file in via Submit CP.
Let's take an example of March 13th 2AM.
When audit log is executed for a particular time window the system errors out because at 2 AM time jumps to 3 AM and there is no entry in database.
or if Activity is Happening on Nov 2nd @ 2:00 AM all the log will show the check-in happened at 1 AM with a gap.
Proposed solution.
Consistent date time capture using GMT so input and output transaction can be based on either server set timezone or preformatted based on client configured regional time settings.
