Controlling access to Integrity Modeler license features through the flexlm options file
No ratings
If there are 2 PLE licenses available how can it be controlled which users can access those licenses as the default is to take the license so the first 2 users take the licenses unless they specify not to take the license? This prevents the specialist variability Modeling users access the editor licenses.
The method in this video uses the Flexlm options file to control who can use these features:
There are many other licensing features that the options files can control. For details please see Chapter 5 - The Options File in the Flexlm End user guide this can be downloaded from:
Solved the problem easily using this method - also can be used for other areas which have limited licences. The name to use in the opt file (ART_PLE in the example) can be found in the artisan.lic file
