Could I execute CLI commands in machine which does include Integrity client?
ptc-5063479
We are process of integrating JIRA with Integrity 10.3 in which there is scenrios value need to update in Integrity (through CLI command) from JIRA server. Is any way to run integrity CLI commands in JIRA server with Installation of client.
Many thanks in advance.
Regards
Sarath
Hi Sarath,
If you install the integrity client on your jira server, you should be able to run CLI commands.
However, make sure you are shutting down the client after your CLI commands complete, otherwise you will end up with many orphan integrity client processes eating up all the ram on the server.
Hope that helps,
Matt
