There are different chances to look onto access definitions within Integrity Module "Configuration Management":
But whereas Integrity is already checking it, there is no possibility to check ALL valid Access definitions with one glance at a subproject
(specific as well as inherited definitions), neither for that project node, nor for a user/group.
For checking access (= permission) problems there is always the need to check a lot of different levels up to the overall definitions that are not visible without admin gui.
