Create field by using existing one as template
It would be convinient if Fields definitions could be copied like Type definitions in Windchill RV&S Administration tool.
Today when I need to create a new field which is quite similar to one I already have I have to create new Field and then copy carefully all the settings manually from original Field.
5 Comments
olivierlp
Community Manager
Status changed to: Clarification Needed
olivierlp
Community Manager
Thank you for publishing your idea. We need more information as specified in the form you saw in the submission process. (questions below). The more details and context you give to document your idea, the better. Think about ways to educate and convince other Community members to support your idea and present your case to the product management team for consideration.
Please let us know within the next two weeks.
1. Describe your environment: What is your industry? What is your role in your organization? Describe your stakeholders.
2. What product & version are you currently running?
3. Describe the problem you are trying to solve. Please include detailed documentation such as screenshots, images or video.
4. What is the use case for your organization?
5. What business value would your suggestion represent for your organization?
I would also invite you to check out this topic where 2 PTC executives explain product managers' approach to customer ideas and input for product roadmaps.
SM_10187717
6-Contributor
I am requirements management engineer in the company which develops railway transport and infrastructure.
Windchill RV&S 12.5
Using Administration client I want to create a "copy" of Text field which are going to be used to store the translation of original requirement in bi-lingual requirements specification. Practically only field name will be changed. Having current functionality I need to create a new field from the scratch and copy all the settings from Text field manually.
See item 3.
It will shorten the time for tunning up requirment documents.
olivierlp
Community Manager
Thank you for your idea and the information you provided.
olivierlp
Community Manager
