Default settings for SysML Activity Diagrams
0 Kudos
1. Describe your environment: What is your industry? What is your role in your organization? Describe your stakeholders.
As a solution architect in the medical device industry I support users of the MBSE tool PTC Modeler.
2. What product & version are you currently running?
PTC Modeler 9.5
3. Describe the problem you are trying to solve. Please include detailed documentation such as screenshots, images or video.
When creating SysML activity diagrams with (Allocate) Activity Partitions, it is not possible to save default settings for the view options of activity allocations (e.g. vertical display of activity allocations as the default in a model)? It would be great to have this possibility.
4. What is the use case for your organization?
When creating SysML activity diagrams with (Allocate) Activity Partitions, the view options for each activity diagram need to be customized manually.
5. What business value would your suggestion represent for your organization?
This suggestion would lead to time savings and simplify the modeling process.
2 Comments
PatrickOllerton
I don't know if it will work for your specific needs, but have you tried using Diagram Defaults feature? It's explained here.
thanks,
Patrick
DS_10069093
8-Gravel
Hi Patrick,
thanks for your help. This is exactly what I searched for.
I just realized that there is no possibility to set the view options for an "Allocate Activity Partition" in a default diagram.
Is there a way to also define view options for Allocate Activity Partitions in Activity Diagrams?
David
