Difference viewer: allow to modify field options in difference result
0 Kudos
It would be nice to modify the output options of the difference viewer while you are already in the result. Now, a user has to go through the entire wizard (incl. document and date selections) for a small output change.
The user already has the capability to show/hide unchanged items/fields through the View menu. The request is to also add/remove fields from the output.
1 Comment
olivierlp
Community Manager
Status changed to: Archived
