The tab title does not distinguish the different document domains by an icon. Currently for all domains (input, requirement, design, test, model, etc.) the same icon is used. A differentiation would make it easier to see at the first sight which document domain a document belongs to. Especially if many documents are opened in parallel this would improve usability. This will help user to get better overview of the opened tabs when the type is clear with one glance.
