It would be nice if we could disable the TEXT field in the document difference view.
In cases where only other metadata like "state" or "priority" are relevant, it would really help if these could be defined as the only fields in the View.
From a technical perspective I can understand why the TEXT is mandatory to do the matching (e.g. in a free comparison of two diocuments without a branch oder version relation) but nevertheless it should be possible to hide the TEXT from the view.
