Document in multi edit mode does not save session when one updated item is constrained
0 Kudos
In multi edit mode of a Requirement Document, if the change of one Requirement cannot be saved due to a constraint in the configuration, also all the other updated Requirements are not saved, too. The complete work of the update session is lost. Proposal: All item which can be saved should be saved when pressing Ctrl-S to avoid that the user has to do the complete rework of the document again.
1 Comment
olivierlp
Community Manager
Status changed to: Archived
