When synchronizing a formal module in Doors to my model, you can use the option to import unsynchronized objects as packages (these are the chapter titles created in the formal module - objects with only the Object Heading attribute filled). Today, synchronizer bring these objects as packages into the model and the child objects as requirements inside these packages. For an organizational point of view, it would be good if synchronizer could bring the Object Number as well to compose the name of these packages. For example, there is an object in the formal module with Object Heading = "Introduction". When opening the formal module I see the object formatted as "1 Introduction" (Object Number appended to the Object Heading to show a nice organization). When this object is brought by synchronizer, the package is named like "Introduction". It would be good to have this package named like "1 Introduction". Like this, packages would be nicely ordered in the browser and it would be easier to find requirements there.
