The following error occurred while trying to attach a file which has more than single space between two words in the file name:
Could not save modified item <item no>: MKS947665: Please rename attachment "<attachment_file_name>" in field Attachments as multiple consecutive spaces in file name are not allowed
Support to have the ability to properly handle files with multiple consecutive spaces in the file name.
Usually happens when using drag & drop with e-mails (e.g. RE: <SomeText>) and very annoying for users.
See also https://www.ptc.com/de/support/article?n=CS173121 for existing article.
