Enable multi-valued fields for QBR "field correlation"
Currently the very usefull combination of IBPL and QBR field to create and analyze "uni-directional" links between items can only be used with single value IBPLs.
Multi-Valued IBPL fields are not supported by the QBR as they cannot be selected for Field Correlation.
In addition to the "equals" correlation for single-valued fields, a "contains" correlation should be possible for multi-valued fields.
3 Comments
smccoy
Newbie
Yes. Please do this.
PTCModerator
Topaz I
alno
Visitor
Are there any workarounds?  A large customer needs this functionality.
Use case:
Out of the box, a Test Session can have only a single value relationship to a Test Objective.
In this use case a Test Session can have multible Test Sessions. Due to the limitation, the Active Session field of Test Object is empty, where it should show all related Test Sessions.
Any ideas would be appreciated.
