Currently the very usefull combination of IBPL and QBR field to create and analyze "uni-directional" links between items can only be used with single value IBPLs.
Multi-Valued IBPL fields are not supported by the QBR as they cannot be selected for Field Correlation.
In addition to the "equals" correlation for single-valued fields, a "contains" correlation should be possible for multi-valued fields.
