Enable one instance of client GUI per viewset
It would be nice, it the Client would support, multiple instances of the Client.
E.g. with a two monitor environment it should be possible to "split" the client into two different instances for two different viewsets (one per monitor).
Currently this is only possible for views but not for viewsets.
This results in various limitations, as e.g. some Settings related to the document view, are stored only in the viewset, but not used in the General "segment view".
Please vote for this IDEAs
Start Client GUI with a Viewset Parameter
Make viewsets "shareable" like queries, charts, reports and dashboards
as well
5 Comments
VolkerEckardt
Hello Mr. Rump.
Would installing the client twice help?
Regards
mrump
It would shurely be better than nothing.
But honestly that cannot be an "official" solution
VolkerEckardt
Well, this approach is official, I mean it is supported and can be used by any user.
Integrity runs in a JVM and in it you can have only one instance. If you force another JVM you can have exactly what you were asking for. (by installing the client again and configure the local configuration accordingly)
KartikOak
     There is No Plan to Implement this feature, you can consider using the alternative solution suggested by Volker.
Kartik Oak
KartikOak
Status changed to: No Plans to Implement
