The PTC Community email address has changed to community-mailer@ptc.com. Learn more.
Enhance Native filter capability in reporting to view inserted / included document
Pre Condition
  A Segment is created. Multiple documents are inserted
A report needs to be created using existing report recipe Detail, HTML Column Relationship structure and using relationship filter.
Proposed solution
Current configuration needs adjustment to report recipe and hence re-coding report recipe for a specific case.
It would be nice if relationship filter can be used to filter segments for inserted / included documents.
2 Comments
GauravPhadtare
Hi Pratik
There is a way to filter out inserted/included documents in current Integrity version. Please look at the images added below. Could you please go through it and let me know if it addresses your concern and if not could you please elaborate your requirement?
  • In the following image, item 4945  is an inserted document. After applying correct filter, the inserted document gets filtered out from the report.
Relationship Filter Used:
cid:image002.png@01D29BEC.5270B170
olivierlp
Community Manager
Status changed to: Archived
