Enhancement of mksapiviewer im viewfield
0 Kudos
In the GUI you have the possibility to select between three options when you create a field from data type "Long text": Logging=None, Logging=Most Recent Last or Logging=Most Recent First.
If you run the mksapiviewer, it is only possible to get the Information:
<Field name="loggingText">
<Value dataType="boolean">true or false</Value>
</Field>
It is not possible to distinguish if Logging is set to Most Recent Last / or Most Recent First.
PTC Idea: Extend the mksapiviewer im viewfield command to provide also the properties "Most Recent Last" and "Most Recent First".
1 Comment
olivierlp
Community Manager
Status changed to: Archived
