1- Open document to see requirements.
2- Right click on column -> Configure Column -> Add (this is one example)
3- Now we have a "filter" panel and here is the "enhancement" proposed.
3.1 Once we are seeing requirements, request is to see just fields with requirements relation, today we see all fields, "varies" for example is a field by Element type.
Or once we did set up manually using "there are" option:
Configure Columns’->’Add’->’that are’->’visible in item type’->’Requirement’
We can save it to use more easily. User is not feel good to do all time this set up manually.
