Export to Word
blercher
Export to Word
Hi all,
how I can export a specification to word (docx, 2010)?
With Document->Export->Simple Exporte I receive an error message (see attachement)
Where I can see the prefix of our solution in integrity?
thx
Bernd
1 ACCEPTED SOLUTION
Bernd,
Have you taken a look at this guide:
http://support.ptc.com/WCMS/files/160839/en/GatewayUserGuide_10_5.pdf
It should have more information about setting up exports to Word files.
Bernd,
There is also this article that has more information on the error you are getting:
https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS132252
blercher
(To:jgorsline)
Hi Jeremy,
thanks for your help. It works now
KaelLizak
(To:blercher)
Hello Bernd,
I'm glad to hear your export is working now. If one of Jeremy's posts in particular helped, could you mark that post as correct by pressing the Correct Answer image for it, so that anyone else running across this problem can quickly see what helped you reach your solution?
-Kael
Kind Regards,
Kael Lizak
