FVA - Field Value Attribute
ptc-4830025
I am new to this tool and still in the process of configuring fields, types etc. Could someone please explain the significance of 'Field Value Attributes (FVA)'?
When should a field belong to this type? I read the part in the Server Admin guide, but I didn't understand the concept fully.
Snehal.
1 ACCEPTED SOLUTION
An FVA field can be thought of as a pointer to the field on a related item. You specify a field which you want to mirror from one type to another and you specify the relationship field to follow. The attached diagram may help visualize the functionality.
Now when a user has an item of Type A and Type B and views that Type B item, they will see a field which appears to have the same value as on the related Type A item. When the value of Field 1 on Type A item changes, the value will automatically be reflected on Type B item.
