It would be nice to have a feature/property to set the URL for images in presentation templates. This is valuable when and existing database is restored on a new server/database. In that scenario the Image URLs of the old host are carried over. Therefore when documents are opened in Integrity Client, the image do not load. To resolve this you need to go to each presentation template, click on each image and correct the host name of the image URL. If this is maintained in a property you need to change the hostname in only that property value.
