Currently, in order to fill a SI Project field, it takes quite some time to navigate to the correct subfolder and select the relevant checkpoint/snapshot.
It would be beneficial if it could also be done via drag & drop from the Project History View.
Please note that SI Project fields apply to project/subproject/checkpoints, and Source Trace/Link fields apply to member revisions.
Some consistency would be great: SI Projects allow browse but not drag and drop, and Source Traces allow drag and drop but not browse. We'd like both types of fields to support both types of gestures.
In Addition to this very good idea i would like to have a possibility to prefill SI Project Fields, so that the user, if he has to use such a field, can start at a certain point or subproject of the structure and not from the highest level of Toplevel Projects.
