1. Describe your environment: What is your industry? What is your role in your organization? Describe your stakeholders.
As a PTC reseller we had queries about this functionality from some of our customers.
2. What product and version are you currently running?
12.5
3. Describe the problem you are trying to solve. Please include detailed documentation such as screenshots, images or video.
Is it possible to define the font size for a field using the Microsoft Excel integration for Windchill RV&S? Basically every field once syncronised with Windchill RV&S will be created with the default 10 pt font size. Is it possible to define different font size for a field?
4. What is the use case for your organization?
Some of our customers would like to have this functionnality.
5. What business value would your suggestion represent for your organization?
The possiblity to customise requirement documents via the Microsoft Excel integration would save time for the end users.
