When a user tries to connect via the WEB interface to the Integrity Application and inserts the Address as http://<integrity_server_hostname>:port/im the request is not automatically forwarded to the HTTPS address:
https://<integrity_server_hostname>:port/im
This is a basic functionality that is generally implemented by any website and should be also implemented for Accessing the PTC Integrity Web Interface.
At this point there is a random Webpage opened that doesn't even represent an Error message nor does it give you the possibility to access the correct link (see Attachment).
