Functionality to print item info based on an idea: "What you see is what you get"
0 Kudos
Our customer wants to print item info from item edit window.
They want to have the info printed with the conditions below:
   1. print all info exactly the same as the one displayed in the item edit/display window
         *do not change the field name display area width to field value display area width ratio
         *do not auto-return new lines in whatever case
            just print as it is shown in the item window
    *do not try to print all row info in the list field even in case where horizontal direction scroll is required
   2. insert page break in front of a field only where the end of a page divides the field contents
In short, they want exactly what they see printed on a paper with 100% item window width covered
and without field info divided by page breaks.
4 Comments
ymizushiro
Posted SPR 9528685 by Tech Support.
GauravPhadtare
GauravPhadtare
Status changed to: Under Consideration
olivierlp
Community Manager
Status changed to: Archived
