Gateway Wizard => varaint-specific Export
M_Mayer
6-Contributor
Hello everybody,
i´am trying to set up a Word-Export-Configuration to generate an variant-specific Export, but unfortunately it doesn´t work out.
My document has got an attribute called "Device ID" used to assign variants to the requirements. On the tab "properties" we have another attribute called "Export ID" used to define the needed variant for the Export. (see figure)
In this case i want to make an Export for variant "C0101"
How can this be implemented?
Many thanks in advance!
1 ACCEPTED SOLUTION
M_Mayer
6-Contributor
(To:M_Mayer)
Problem is solved.
Thanks!
M_Mayer
6-Contributor
(To:M_Mayer)
Problem is solved.
Thanks!
