Get field value of a related Test Document inside a report recipe
Visitor
Hello friends,
     I am trying to create a Custom Recipe in PTC Integrity 10.9 for a report where I need to fetch the field value of a document that is related to the document that has been passed as an input to the report.
var fieldvalue1 = <%fieldname1%>;
var fieldvalue2 = <%fieldname2%>;
Here, I want the fieldvalue2 to be value of the field "fieldname2"as per the document that I got as "fieldvalue1".
I am very new to Integrity custom report creation. Appreciate your help.
Re: Get field value of a related Test Document inside a report recipe
To specify a relationship field rather than the item field, you need to use <%Relationship fieldname2%>, within the <%beginrelationshipdetail relationshipname%> section of the report.
There are some example report recipes using relationships (e.g. Detail - HTML, Row, Relationships). If you create a report using the recipe, then view the report on the CLI using im viewreport reportname, you can see how the field values are defined.  Here's a sample relationship section of a report created from the Detail - HTML, Row, Relationships recipe:
<!-- Relationships info -->
<tr class="odd_row">
    <td colspan="4" class="border">
        <span class="bold_color_underline">Documented By:</span><br>
        <div class="center">
        <table class="list">
        <%beginrelationshipsdetail Documented By%>
        <%relationshipsortby ID+%>
        <!-- Display relationship issue field headings -->
        <%beginrelationshipsection header%>
        <tr>
            <th>ID</th>
            <th>Type</th>
            <th>State</th>
            <th>Document Short Title</th>
        </tr>
        <%endrelationshipsection%>
        <!-- Display no relationships found -->
        <%beginrelationshipsection none%>
            <tr><td>No related items.</td></tr>
        <!-- Display relationship issue field values -->
        <tr>
            <td><%Relationship ID%></td>
            <td><%Relationship Type%></td>
            <td><%Relationship State%></td>
            <td><%Relationship Document Short Title%></td>
        </tr>
        <%endrelationshipsdetail%>
        </table>
        </div>
    </td>
</tr>
