I'm Peter, ADMIN of Integrity. It was suggested by some of your PTC colleagues to write my comment/idea here.
'Head revision' column is really missing while checking a Sandbox (attached a screenshot with all available options and related PTC ticket:
So Please make it available in the next edition of PTC Integrity Client the 'Head revision' column in the Sandbox.
"View Member History" indeed is showing the head revision, but I'm posting this comment in here, because all of my colleagues is having the Member History tab always ON in "Dynamic" mode cause they are aware of the Head revision, but set in a different panel.
Also the opened "Sandbox" is viewable in Dynamic mode, so it would be great, if this head revision column would be an option, really. Thanks for your consideration. Please write to me, if you had any questions. peter.bartha@avl.com
